Date/Time: Fri, 18 Oct 2024 04:46:47 +0000
volume value area lines
View Count: 945
[2014-02-14 00:04:46] |
User17402 - Posts: 5 |
would it be possible to add a feature to this indicator, to the "time period type". can you add an option to pick the number of bars to use, instead of just minutes. I would like to use this indicator on volume charts, but not use it based on minutes, but rather used it based on bars - like 1 bar or 2 bars, etc. thanks if you are able to do this. |
