Date/Time: Wed, 09 Sep 2026 15:41:51 +0000
[User Discussion] - Need help with "High/Low for time period"
View Count: 798
[2020-11-17 12:50:48]
User685606 - Posts: 29
I am having an issue with my "High/Low for time period" that I don't know how to fix. I want 2 ranges for each US trading session, but I don't want the lines for different days to connect. B is what I want (2 well defined ranges each day that don't connect to the next or previous day) but A is what I have. How do I fix A?
Date Time Of Last Edit: 2020-11-17 13:09:14
imageH and L 1.png / V - Attached On 2020-11-17 12:50:18 UTC - Size: 46.69 KB - 354 views
imageH and L 2.png / V - Attached On 2020-11-17 12:50:25 UTC - Size: 88.28 KB - 284 views
[2020-11-17 12:56:17]
Ackin - Posts: 1865
change drawstyle?
For example to "DASH"
[2020-11-17 12:57:04]
Sawtooth - Posts: 4351
Change the DrawStyle from Line to Dash.
Also, set 'Display High Low Incrementally' to No.
Date Time Of Last Edit: 2020-11-17 13:01:05
[2020-11-17 13:01:05]
Changing the DrawStyle to Dash did the same thing, just with dashed line all the way across multiple days like my solid line on Chart A.
Date Time Of Last Edit: 2020-11-17 13:08:50
[2020-11-17 14:09:47]
It appears your orange lines are the H/L for the day, which seem to change properly each day.
The blue lines appear to be the problem. For an Initial Balance, try using the Initial Balance study.
Date Time Of Last Edit: 2020-11-17 14:11:55
