Date/Time: Wed, 12 Feb 2025 21:04:31 +0000
All charts symbol change in 1 place
View Count: 1307
[2020-11-17 12:11:56]
User210127 - Posts: 23
Hi support,
A couple of questions:
1. is there a way to change symbol for all the charts and all the tabs etc in 1 chartbook in 1 simple step without having to go into each chart to change symbol?
2. Can we attach 2 detached charts together i.e. not linked to the main window?
Many thanks for your help.
[2020-11-17 14:47:22]
caligola - Posts: 116
1) I usually link charts symbols
Working With Charts: Chart Linking
then I have only to change it in one of my charts with chart settings
Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings
you can also use a watchlist
Changing the Symbol of a Chart: Using the Associated Watch List
[2020-11-17 17:05:19]
John - SC Support - Posts: 37910
1. We are not sure what exactly you are asking in your first question, so we'll answer both possibilities. First, if you are referring to when you have a change in your service, or due to the change in symbol naming, as we have done recently, then you can update all the symbols to the new service setting by selecting Edit >> Translate Symbols to Current Service. Refer to the information here:
Edit Menu: Edit >> Translate Symbols To Current Service
Second, if you are asking about how to change between different symbols, then answer is to have the charts linked. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
2. We are also not sure what you mean by this question. You can link charts that are detached, just like any other chart. But there is no provision for grouping detached windows together.
