Date/Time: Wed, 12 Feb 2025 21:01:54 +0000
[User Discussion] - Space between bars and VbP
View Count: 689
[2020-11-17 10:21:17] |
User612659 - Posts: 4 |
Hello Is there a way to increase the space between bars and VbP? For a visual backtest I would like to see all bars and VbP without overlap. Having VbP on the left is no help either, then the first bars are simply covered. Many thanks in advance http://www.sierrachart.com/image.php?Image=1605607589225.png |
Attachment Deleted. ![]() |
[2020-11-17 10:53:47] |
Ackin - Posts: 1865 |
Read this in the documentation, maybe it will help you solve what you need: Working With Charts: Right Side Fill Space Chart Settings: Number of Forward Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu) |
[2020-11-17 12:45:10] |
Thank you Ackin. I already read about Fill Space but it did not help. When i move the bars to the left the Vbp is moving along with them. They are kind of sticked to the last 1-2 bars.
[2020-11-17 12:53:07] |
I see, I thought of it before for only one single profile. In my opinion, there is no solution to this while maintaining the size of the scale x axis. Have two separate charts and one numeric and one profile information. Or display only the last bar profile in the Fill space. |
