Date/Time: Wed, 12 Feb 2025 21:56:48 +0000
Deciding Value Per Point for different Instruments
View Count: 471
[2020-11-17 09:25:25]
PS2004 - Posts: 47
When I'm using the Study Angle how should I decide the Value Per Point input's value for different Instruments?
For exmaple the NQZ20's value format is 0.01 but it works well when the Value Per Point is set to 1.
The AAPL's value format is 0.01 too but when the Input is set to 1, it does not work properly.
Is that possible to write a Study Function which can determine the correct Value Per Point for every Instrument in general?
[2020-11-17 21:29:30]
No, it really depends upon the range of prices.
