Date/Time: Thu, 24 Sep 2026 00:54:39 +0000
Footprint Frozen
View Count: 834
| [2020-11-17 00:04:24] |
| User101094 - Posts: 8 |
HI,I open my chartbook today,I noticed that my 30minutes footprint doesn't move but my DOM yes Any suggestion how to fix it?never had this problem. I have another question,how can I fix the scrollbar in the bottom that cover the time? Thanks for any help |
| [2020-11-17 06:17:59] |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart What is the question you have about the scrollbar? We do not understand the question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-17 12:24:48] |
as you can see from the screenshot I can't see the time because the scrollbar is covering it....the question is how can I fix it?Thank you.
| [2020-11-17 16:46:12] |
| John - SC Support - Posts: 47994 |
Your cause and effect are incorrect. The scrollbar has nothing to do with the time scale not showing. Refer to the following setting and make sure it is not enabled: Chart Settings: Hide Time Scale (Chart >> Chart Settings >> Scale menu)) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-17 21:30:43] |
In case the window edge is beyond the visible area of the container window, you can use one of the Tile commands to resize the windows to fit: Window, CB and CW Menus Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-17 21:30:55
