Date/Time: Wed, 12 Feb 2025 22:28:39 +0000
VWAP Start Time & Draw Style
View Count: 613
[2020-11-16 23:35:16] |
User292326 - Posts: 13 |
Hi, I have a vwap study that starts at 16:00:00. I want to be able to use the draw style of line and line style of Dash but this causes the end of one session to connect to the other. The only alternative I have found is to use the draw style of Dash, but then the line doesnt connect on an intraday basis. Essentially, I am looking for it to plot the way it does when I have draw style of line and line style of dash, but I want it to not connect to the next days start, which only happens in a draw style of dash. Hopefully someone can assist me with this.
[2020-11-17 16:15:12] |
John - SC Support - Posts: 37916 |
The specific option you want is not available. You have found the best options available.
[2020-11-17 16:26:18] |
Ackin - Posts: 1865 |
John - SC Support The specific option you want is not available. It would be nice to have a new Drawstyle: "Drawstyle LineSkipZero with the property automatically inserted zero-value into the last bar of the trading session instead of any value what is there." This would be applicable to more studies than just VWAP |
[2020-11-17 21:29:45] |
Regarding the first post, this is the relevant section in the documentation for this: Chart Studies: Avoiding Vertical Joining Line for Study Subgraphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-17 22:08:56] |
Thanks. I've found the dash to be the best alternative. When plotting vwap, the line doesnt connect when the style is set to dash. I want it to be continuous the way it is with line but not have the vertical connecting line like you have with Dash. If the solution exists, I'd be thrilled but as John mentioned above, it doesnt appear to.
