Date/Time: Wed, 12 Feb 2025 21:22:17 +0000
Quoteboard not registering ESZ20-CME
View Count: 482
[2020-11-16 16:52:44]
User707430 - Posts: 7
I have reloaded and redesigned quoteboard but I cannot get data on ES December contracts. ESH21 shows up. resolution?
[2020-11-17 17:40:23]
John - SC Support - Posts: 37912
If you have switched to using the new symbol format for any symbol, then you will need to use that new format for all symbols. First, you can update all symbols by using the option Edit >> Translate Symbols to Current Service. Then make sure that you are using that new format for all symbols going forward.
If this is something else, then please attach your Message Log to this thread following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
