Date/Time: Thu, 13 Feb 2025 02:59:27 +0000
.dll file will not load in custom studies.
View Count: 919
[2020-11-16 15:33:58] |
Brian Connolly - Posts: 9 |
I just loaded the most recent version of Sierra Charts software. I previously had the emini-player_64.dll custom study loaded and working. Now after installing the new version the custom study has disappeared from the custom study add study page. The emini-player_64.dll file is loaded in the Sierra Chart Data folder but doesn't load in the add studies. This study worked fine prior yo the update. Brian |
[2020-11-17 22:29:42] |
It may need to be recompiled for the newer versions of Sierra Chart. Refer to: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156 (Version 2156) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-20 05:35:53
[2020-11-19 19:35:45] |
The referred o page is just a list of up dates that have been added to the software. I am not sure what you mean by recompiled or how to do that. I don't see a mention of recompiling of the referred page Brian |
[2020-11-20 05:36:18] |
Is this a study that you developed or that you obtained from someone else?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-20 05:36:26
[2020-11-20 14:15:34] |
The study is for the eminiplayer zones and was developed by Awais Bokhari at eminiplayer.
[2020-11-20 15:19:22] |
Ackin - Posts: 1865 |
So you have to contact the author of the study to send you a version of the study/library compatible with the current version of Sierrachart. Sierrachart programmers have no chance to "revive" the old library for a newer version of Sierrachart. |
