Date/Time: Fri, 07 Feb 2025 15:05:57 +0000
Coloring Bars Based on Volume
View Count: 1737
[2020-11-16 15:29:31]
User229219 - Posts: 1
Buenos dias, existe alguna herramienta o indicador que cambie de color en base el volumen la vela del grafico? gracias
kamal
[2020-11-16 18:02:01]
John - SC Support - Posts: 37808
From Google Translate:
Good morning, is there a tool or indicator that changes color based on the volume of the candle on the chart?
There are a number of different ways to do something like this, so it depends on what exactly you are looking for.
One item you can use is the Color Bar Based on Alert Condition study where you can define a condition that would color the bar a certain color based on the condition (like a volume greater than some value). Refer to the information here:
Another option would be the Numbers Bars Calculated Values study where you can display the Volume of each bar and color the background of each cell in the study based on the volume percentage relative to the Maximum. Refer to the information here:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
