Date/Time: Wed, 12 Feb 2025 22:05:10 +0000
Study Settings: Single Bar Volume Profiles with Bid Volume and Ask Volume
View Count: 642
[2020-11-16 12:46:31]
User158085 - Posts: 4
I want to set this study, Part 7, Setting and Inputs, but some values cannot be changed. For example, if I want to change "Volume Graph Period Type" to "Multiple Profiles Based on Bar Count", the value jumps back to "One Period at End of Fixed Time Lenght" after clicking apply. The same with others. What is the reason? What can I do?
[2020-11-16 17:31:43]
John - SC Support - Posts: 37915
Are you using the Volume by Price study from within Sierra Chart, or are you using a special study named "Part 7"?
If this is a custom study, then you would need to ask the developer of the study about how it works.
If this is the Volume by Price study, then we would need to know more about where this study is being used and what else is happening on the chart.
[2020-11-17 22:17:17]
Are you using the Volume by Price study on a Trading DOM?
Date Time Of Last Edit: 2020-11-17 22:17:45
[2020-11-18 09:39:13]
No I donĀ“t. I want to use it with blank chart. I want to create a footprint chart.
