Date/Time: Wed, 12 Feb 2025 21:27:06 +0000
live stocks
View Count: 568
[2020-11-16 12:25:36]
Osama Elgammal - Posts: 10
hello
stocks are not live , why is that? is there a setting i need to do? for example stock MRNA is like 1 hour delayed
Date Time Of Last Edit: 2020-11-16 12:52:26
[2020-11-16 17:26:09]
John - SC Support - Posts: 37912
In order to get Real-Time data for stocks, you would need to pay for it. If you want to get your data from us, then you can use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. Refer to the information here:
You can change the interval at which the historical data is updated. Refer to the information in the second paragraph of step #15 here:
Sierra Chart Historical Data Service: Setup Instructions
[2020-11-17 12:40:24]
can you please check my account subscription to make sure i signed in to receive us equities live stocks correctly ?
Date Time Of Last Edit: 2020-11-17 12:53:26
[2020-11-17 16:46:47]
Yes. You are now setup properly. Let us know if you are having a problem getting the data.
