Date/Time: Wed, 12 Feb 2025 21:28:50 +0000
Bitmex service stop updating
View Count: 455
[2020-11-16 06:27:58] |
Andrew Ton - Posts: 28 |
Hi, My chart stop updating from bitmex connection. I did multiple reconnection, restarts, etc but those didn't help. Please help me restore connection. Thanks. |
[2020-11-16 06:33:46] |
anpy - Posts: 35 |
same here
[2020-11-16 08:04:29] |
We are not seeing any problem with BitMex data at this time. There is no missing data. Are you receiving data now?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-16 08:04:39
[2020-11-16 08:07:27] |
anpy - Posts: 35 |
yes, started receiving data again a few minutes after my post.
[2020-11-16 08:36:24] |
Ok that must have been a BitMex issue then.
