Date/Time: Wed, 12 Feb 2025 22:22:23 +0000
CADJPY - Intraday not updating [SC DATA - All Services]
View Count: 520
[2020-11-16 05:49:13]
User52897 - Posts: 47
CADJPY - Intraday not updating ???? [SC DATA - All Services]
Other FX pairs GBPJPY, GBPUSD, EURUSD are intraday updating
To Support: Please investigate
[2020-11-16 16:11:00]
John - SC Support - Posts: 37916
We are not seeing any issue with the CADJPY symbol.
If you are still having a problem, then please attach your Message Log following these instructions:
Open a chart for the symbol you have an issue with.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2020-11-16 16:31:55]
Thank you Sierra Support - for the benefit of other users resolution below.
I had these settings: Chart Settings >> Main Settings >> Use Date Range -> From: [ xxxx-xx-xx ] To: [ xxxx-xx-xx ]
I had both From: and To: fields filled which was limiting this pair update between the two dates.
Resolution: Chart Settings >> Main Settings >> Use Date Range -> From: [ xxxx-xx-xx ] To: [ ]
For data to update in real time the To: [ ] field must be blank !
Date Time Of Last Edit: 2020-11-16 16:39:43
[2020-11-17 22:28:49]
This is explained here already:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.9 - Options that Disable Chart Updating
