Date/Time: Mon, 21 Sep 2026 16:54:14 +0000
Live data not showing up
View Count: 1251
[2020-11-15 23:18:02]
User823684 - Posts: 14
Hello
I am connected to the SC Order Routing/Data in my server settings, the market is open, the connection is active (green), yet no live data is showing up. What am I doing wrong? I am attempting to stream the Dow Futures MYMZ20 data.
[2020-11-15 23:39:40]
Make sure you are using the correct symbols. Select Edit >> Translate Symbols to Current Service:
Edit Menu: Edit >> Translate Symbols To Current Service
[2020-11-15 23:52:00]
Ok I did that and it brought up current data, but not live data. It seems at least 2 minutes delayed from what I can tell between the last closed bar (10 tick bars) and the present time.
[2020-11-15 23:57:01]
OK in the message log the following:
"SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2020-11-15 23:54:28.505"
I am running the live data off a server and delayed data off my home computer, or so I thought. Is "SC Data" not delayed data? I thought that was the difference between SC Data and SC Order Routing/Data servers.
[2020-11-15 23:59:40]
Ultimately I would like delayed data on my home computer and live data on the server.
[2020-11-16 00:12:35]
I got it now. Had to uncheck the Allow SC Data... on the home computer.
