Date/Time: Wed, 12 Feb 2025 21:21:53 +0000
cpu sPIKE OF 100% ON STARTUP
View Count: 489
[2020-11-15 22:07:27] |
timdug1 - Posts: 14 |
Hi, When I start SC I regularly get a spike to 100% CPU Usage. I'm running an i7and 6GB of ram and 8GB of dedicated GPU. I must be doing something wrong with this much RAM and still spiking to 100% for about 30 seconds on startup. I have streamlined as much as I can from looking at the CPU usage streamlining thread on the help section here. But I still dont see a performance enhancement. Here is a log. |
[2020-11-16 18:41:06] |
Most likely that relates to the loading of Intraday chart data. We recommend getting more CPU cores and also using a dedicated solid-state drive: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.29 - Solid State Drives / SSD Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-16 18:41:12
