Date/Time: Wed, 12 Feb 2025 21:08:24 +0000
volume profile low volume lines
View Count: 711
[2020-11-15 18:37:25]
User318521 - Posts: 47
Hello, is there any way you can get the valley lines in a volume by price study from say a 16 range chart to display on a 5 tick range chart with the study /price overlay study, or any other study. If not, could you try to program this into the program? I know you can do this study on the 5 tick and adjust but it doesnt quite show the information needed. thanks
[2020-11-16 18:39:59]
No those lines cannot be overlaid to another chart.
[2020-11-16 18:50:12]
Ackin - Posts: 1865
Could you send an image / screen of what should be the result? Maybe it's solvable.
[2020-11-17 10:58:23]
Ackin - Posts: 1865
ok...so nothing.
