Date/Time: Wed, 12 Feb 2025 21:03:39 +0000
Scaling out
View Count: 486
[2020-11-14 20:30:37] |
User575399 - Posts: 326 |
I want my dom bracket to have 2 targets . Total position is 3 contracts . Scale out 2 contracts at 20 points and leave 1 contract runner to 40 points .My question is , shouldn’t my STOP (20pt) configuration read 3 contracts since I’m only scaling out profits , not exit? Then as my 2 contract profit gets hit the stop amount will drop to 1? See attached pic
Date Time Of Last Edit: 2020-11-14 20:59:34
Private File |
[2020-11-16 14:49:24] |
John - SC Support - Posts: 37910 |
That stop is just for OCO Group 1. You would need to change the setting in the Group to be All OCO Groups. Then it will cover the full quantity that you enter. Refer to the information here: Attached Orders: OCO Group (Group) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
