Date/Time: Wed, 12 Feb 2025 21:15:28 +0000
Subgraph Auto-coloring: range-based gradient
View Count: 482
[2020-11-14 16:33:55] |
User311344 - Posts: 142 |
Hey, There is a angle based gradient subgraph auto-colloring method. It would be cool if you could add an auto range based gradient colloring. So there should be 2 inputs: MinValue and MaxValue so if a sugraph has a value at MinValue or below it means PrimaryColor and when MaxValue or above it means SecondaryColor. And all values between as gradual change between Primary and Secondary Colors. You have the color logic ready as for angle based gradient so it should be a quick thing do do and it would be much more usable than only angle-based gradient. Thanks in advance! Date Time Of Last Edit: 2020-11-14 16:34:55
