Date/Time: Sun, 24 Nov 2024 04:31:23 +0000
Extending Rectangle
View Count: 2012
[2013-04-18 10:16:02] |
User95130 - Posts: 9 |
Hello, I would like to ask, if it's somehow export "Extending Rectangle" and then load up to another installation sierra. For example, in the "Tools> Show All Drawings Windows" I would expect click "Import and Export". Thanks for the answer. Jan. |
[2013-04-18 19:45:00] |
What you need to do is save your Chartbook that contains the chart or charts that have the Extending Rectangle drawings. You then need to copy that Chartbook to another installation of Sierra Chart. Here is the documentation for this: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#CopyChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-18 19:46:37
[2013-09-15 14:37:04] |
Hello, but I need every day to save SR zones (Extending Rectangle) in a separate file with a name such as "SR_zones_09102013.txt" and on backtest I can open these saved SR zones for any day in the past. It is now possible somehow in Sierra Chart? Thanks for the answer. Jan. Date Time Of Last Edit: 2013-09-15 14:46:14
[2013-09-17 05:26:13] |
No, this is not supported.
