Date/Time: Wed, 12 Feb 2025 21:30:57 +0000
Trailing stop help
View Count: 525
[2020-11-14 00:56:08] |
skyins_q - Posts: 2 |
Question, How do you first move to breakeven 5 ticks on two contracts, and subsequently leave 1 contract to set 5 tick offset trailing stop loss? Sincerely |
[2020-11-15 11:00:47] |
You need 2 separate Stop Attached Orders: Attached Orders: Using Attached Orders and Attached Order Settings One of them needs to use the Move to Breakeven for Stops settings: Attached Orders: Move to Breakeven for Stop And another stop needs to be a trailing stop: Order Types: Trailing Stop Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
