Date/Time: Mon, 14 Sep 2026 16:04:01 +0000
Sierra Order Routing Costs
View Count: 790
| [2020-11-13 22:10:40] |
| User750920 - Posts: 297 |
I want to be sure I understand the cost correctly. I currently am paying my platform fee. If I add the Sierra Order Routing with AMP my cost for Denali Data cost will go down from $25 to $20 per month. The other cost I will incur is the TT per side/per contract routing fee of $.10 per side/per contract. Is this all correct and are there any other costs I will incur? Also can you point me to what I must tell AMP and the subsequent setup for the Platform to accept the Sierra Order Routing. Thank you. |
| [2020-11-14 07:19:42] |
This is all correct and there are no other costs. To proceed you just need to complete this form: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-14 19:12:58] |
Thank you. Would I be able to trade from an external trading platform or only with the Sierra Platform?
| [2020-11-16 19:13:43] |
Only with Sierra Chart in this case but we also have the web-based trading panel: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-17 14:32:51] |
When I switch to Sierra Order Routing will I need to change the symbols on all my charts (after moving my account from GAIN)? Also I was looking at the Sierra DOM and did not see OCO orders button. I assume they are able to be done - can you point me to where I can see all how to enter all orders and the various options for the DOM and which orders are server held - etc. Thank you. |
| [2020-11-17 21:17:33] |
We have developed this new command to automatically translate the symbols: Edit Menu: Edit >> Translate Symbols To Current Service (Edit menu) Also I was looking at the Sierra DOM and did not see OCO orders button. For this you would use Attached Orders:Attached Orders Attached orders are managed on the server in the case of the Sierra Chart Order Routing Service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-17 21:17:52
