Date/Time: Wed, 12 Feb 2025 19:10:01 +0000
Running SC on 2 instances at the same time
View Count: 571
[2020-11-13 08:50:20]
User823684 - Posts: 14
If I am live trading a strategy on one instance of SC (on its own server), if I open a second instance of SC on another computer, will there be any interference between the two? For example, if I pull up a chart and run a backtest on the second instance, on the same asset as the strategy running on the first instance, will there be any conflict with my strategy running?
Also I have paid for the Denali Exchange Data Feed, do I need to pay for a second instance if I want to view data on both instances at the same time?
Thanks for all your help.
[2020-11-13 13:13:31]
No.
No unless you want real-time exchange data on both at the same time.
However, refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#UsingDelayedMarketData
