Date/Time: Wed, 12 Feb 2025 19:23:02 +0000
Need help with a basic chart function
View Count: 473
[2020-11-12 20:08:55]
User726273 - Posts: 4
Hello, I am new to Sierra Chart. When moving the mouse to any bar on the chart (using pointer or ChartValueCrosshair) it does not show the value of high, low, open, close, up and down volume on that particular bar. Anyway to activate that function?
[2020-11-12 22:05:23]
John - SC Support - Posts: 37910
Under the Window pulldown menu you need to enable either the Tool Values Window or the Compact Tool Values Window. Refer to the information here:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
