Date/Time: Wed, 12 Feb 2025 19:24:24 +0000
Load times when changing time frames
View Count: 412
[2020-11-12 16:34:00] |
ssangha84 - Posts: 126 |
Hello, my charts take an excessive amount of time to load when I change time frames. I get messages looking like it is loading old charts and just takes awhile because of that. Is there something I can do about this? I don't want to just delete these old charts without asking the best option. I have attached an example. Please advise what I can do about this, Thanks.
[2020-11-12 17:33:03] |
Refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Also update Sierra Chart to the current version to take advantage of file compression which will help. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
