Date/Time: Thu, 17 Sep 2026 23:55:53 +0000
IB - Exchange traded spreads
View Count: 691
| [2020-11-12 15:28:26] |
| Kajman103 - Posts: 5 |
Hello Sierra, I have a question regarding Spread trading. I am using IB as my broker and would like to trade spreads with DOM from Sierra. I went through many pages on sierra website and I am confused. It is said that: "Futures spreads/strategy symbols for Interactive Brokers are not supported. There is no simple and straightforward format for this, and it has been determined to be impractical to support." On the other hand, there is this option mentioned : "Consider using the Sierra Chart Order Routing Service with Data for trading futures spreads as an alternative." Is it possible to trade spreads from Sierra DOM with IB broker when using Order routing service? Thank you for clarification. |
| [2020-11-12 16:06:46] |
Is it possible to trade spreads from Sierra DOM with IB broker when using Order routing service? No.
