Date/Time: Wed, 12 Feb 2025 22:34:34 +0000
Error Message when attempting to download data for stock chart.
View Count: 597
[2020-11-12 15:10:26]
User964272 - Posts: 2
Hi
There has been a problem that has appeared over the last 2 week when I attempt to load up charts.
I get this error message.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=45277
[2020-11-13 13:46:42]
Tell us the exact symbol of the chart.
Date Time Of Last Edit: 2020-11-13 13:46:48
[2020-11-19 04:01:42]
Hi
The Symbol is (BHP-STK-ASX) or (NAB-STK-ASX) etc
The problem started on the 09/11/2020.
imageSierra Chart.jpg / V - Attached On 2020-11-19 04:00:53 UTC - Size: 424.31 KB - 184 views
[2020-11-19 18:54:16]
Refer to this post about this:
Important Update: "SC Data-All Services" Symbol Cleanup | Post: 241335
Although in your case since you are using Interactive Brokers we need to make a change which we will do now, to make sure that data comes from Interactive Brokers. So that will actually solve the issue.
Date Time Of Last Edit: 2020-11-19 18:55:15
[2020-11-19 19:00:03]
After that, use this command:
Edit Menu: Edit >> Download Data For All Historical Charts
