Date/Time: Sun, 08 Sep 2024 00:42:17 +0000
Volume by Price / Draw Volume Profile
View Count: 1520
[2014-02-13 16:08:00] |
Fxxtrader - Posts: 79 |
Hello, In the VbP and DVP tools, is it possible to display the total volume for the selected bars being calculated by the tool? If yes, how? |
[2014-02-13 18:40:31] |
No. This is not supported. Have a look at using the Chart Calculator tool for this: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartCalculator You need to enable the Labels >> Volume option in the Tool Configuration window for the Chart Calculator tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-13 23:51:11] |
Ok good. Thanks for the response. I saw the Chart Calculator tool and it's very useful. However, it's a manual operation. It would be ideal if the totaling calculation (for the full profile region) could be automatically done to the profiles like it's done in the "Display Value in Bars" field, but as a separate input option. If I may suggest, could both the chart calculator and VbP tools have a summation option for the Ask-Bid calculation, for the full selected area and profile, as well. Thanks. |
