Date/Time: Wed, 12 Feb 2025 19:20:11 +0000
Sierra trading syst based on alert condition
View Count: 464
[2020-11-12 11:08:42]
User657945 - Posts: 226
IN this study you did add a button ACS control bar button for enable /disable the study I look into the istruction and I did not find how to set up a button in the control bar commands.
can you please tell me how to do it?
thx
[2020-11-12 12:23:21]
I found how to do it but in any case should be nice to put a link in the istr manual to go to COntrol Buttons bar 1> then advanced custom study buttons and there you can associate to CS1 the std AC1 enable disable then CS2 the second strategy you want control etc.
bye
