Date/Time: Wed, 12 Feb 2025 19:23:58 +0000
Trouble installing Sierra
View Count: 458
[2020-11-12 03:12:57] |
User241590 - Posts: 2 |
Hi there. I keep getting this error message. Error saving downloaded files to local system. Stopping Installation. Check Log. Press install to retry. I am using the IOS on a Macbook and I have installed the Parallels app. I have also installed Windows 10 through that app. Thank you in advance. Tannan James |
[2020-11-12 03:22:42] |
Try using the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
