Date/Time: Wed, 12 Feb 2025 19:05:41 +0000
Unable to Install Sierra
View Count: 558
[2020-11-11 23:28:50] |
User241590 - Posts: 2 |
Im having trouble installing Sierra. I keep getting the message.... Error Saving downloaded files to local system. Stopping Installation. Check Log. Im using a Macbook and have installed Windows through the Parallel app. Cheers |
[2020-11-12 04:38:18] |
Try using the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
