Date/Time: Tue, 22 Sep 2026 03:25:31 +0000
Order exit issue
View Count: 739
[2020-11-11 13:29:19]
User40526 - Posts: 166
I am having an issue with order entry on exit. I always use an OCO entry with stop and target. Sometimes I exit before either are hit with FLATTEN on the chart trade window. What has started happening is my stop and target are cancelled, the position remains open until I hit FLATTEN a second time, and I get the error message below, which says I am doubling my size - I have deleted the amounts from the message as they don't matter.
If I use a keyboard short cut to flatten this doesn't happen.
Can you tell me what I need to do to stop this from happening.
Thank you
Buy order for F.US.MESZ20 has been Rejected. Internal Order ID: 72259 | Alert: buzzer2 (2)
Trade Order Error - CQG order update. Status: REJECTED. Text: Insufficient margin
Available margin: USD*****
Used margin: *****
Total portfolio margin including this order: *****
This order increases margin by ***** . Internal Order ID: 72259. Service Order ID: 1829372361. Symbol: F.US.MESZ20. Account: Robert H S | 2020-11-11 07:11:50.768 *
[2020-11-11 16:31:13]
John - SC Support - Posts: 47955
Refer to the information here:
Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded
