Date/Time: Thu, 13 Feb 2025 02:47:16 +0000
Hand tool not working
View Count: 744
[2020-11-11 10:48:33]
User187934 - Posts: 40
When I right click to exit drawing tool to hand tool the hand tool doesn't work anymore. After drawing on the chart I used to right click to go back to hand tool and then be able to pull the chart left and right but now I have to manually go and select the hand tool in order to be able to do this. In tool configuration the right click exits drawing tool to setting is current set to hand.
Please advise. Thanks
[2020-11-11 15:59:33]
John - SC Support - Posts: 37916
The new Tool Settings dialog is not correctly saving the selected tool for that setting. We will get this fixed and let you know when we have it done.
[2020-11-11 18:31:33]
Great thank you!
[2020-11-20 08:32:54]
Any updates on this bug fix?
[2020-11-20 15:02:24]
Yes, this was fixed a few releases ago. Sorry we did not inform you. Update to the latest release for the fix.
[2020-11-20 16:06:48]
No problem thanks for the fix
