Date/Time: Mon, 05 Oct 2026 13:04:02 +0000
why the same data/same charbook drawing differnt chart ?
View Count: 821
[2020-11-11 04:40:04]
User845173 - Posts: 6
i uploaded 2 screenshot, first is the correct one. second is the wrong. please advise why the bottom time is different ? and number on the chart is different too ?
imagefirst.png / V - Attached On 2020-11-11 04:35:19 UTC - Size: 105.23 KB - 277 views
imagesecond.png / V - Attached On 2020-11-11 04:35:24 UTC - Size: 87.38 KB - 287 views
[2020-11-11 09:16:29]
Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
[2020-11-12 15:43:02]
sitll not fixing the issues, please advise more.
[2020-11-12 19:59:20]
you see the bottom of the time, candle openings at the different time.
[2020-11-13 13:15:43]
To make these charts the same, close one of them and then duplicate the other:
Chart Menu: Duplicate Chart (Chart menu)
And then also reload each of them with Chart >> Reload and Recalculate. This is only necessary if the chart bars are based upon a variable time frame per bar.
Date Time Of Last Edit: 2020-11-13 13:16:05
[2020-11-13 15:52:11]
these 2 charts are on different servers and same chart settings. this morning i see that intially the time of opening a new bar is same, then it is becoming one second difference, please advise.
imagefirstchart.JPG / V - Attached On 2020-11-13 15:51:23 UTC - Size: 106.78 KB - 358 views
imagesecondChart.JPG / V - Attached On 2020-11-13 15:51:27 UTC - Size: 95.78 KB - 310 views
[2020-11-16 08:33:54]
Really this is the relevant documentation for this:
It is quite detailed for everything to look for.
You are also not using a Sierra Chart provided data feed. You are using CQG which we do not provide technical support for. Consider using the Denali Exchange Data Feed where you will be assured of consistent data between connections:
So that is really the first step, if you cannot resolve the issue when using CQG, is to use the Denali Exchange Data Feed.
Date Time Of Last Edit: 2020-11-16 08:35:23
