Date/Time: Fri, 02 Oct 2026 11:22:07 +0000
DOM Custom Study - Marking Price Levels
View Count: 2296
| [2020-11-10 20:20:14] |
| RolandC - Posts: 54 |
This is difficult to explain, so I will do my best. Take a standard DOM. The price fluctuates between price points. I have seen a Sierra Dom that has an extra column, where you can click a specific price so as to mark that price as a level and then select another price so as to mark that as another level, enabling you to establish which prices in the market the buyers and sellers are battling over. Do you know which study this is? |
| [2020-11-10 21:30:43] |
| John - SC Support - Posts: 48086 |
We're not sure exactly what study you may be referring to, but, in general, studies have the ability to place the name or value of the most recent bar, in either the Price Column or in a special "Label Column". Refer to the information here: Chart Studies: Subgraphs Tab >> Name and Value Labels For example, if you use the Horizontal Lines Study and add 2 lines, you can then go to the Subgraphs tab and turn on the Name and/or Value Labels for those subgraphs and have them displayed in the DOM. With regards to the Label Column, refer to the information here: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ColumnDescription_LabelColumn. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-11-12 11:43:35] |
I am using the Horizontal Line tool and placing lines on the Volume By Price Study. Is there any way to still keep the VBP Column, but also place that Horizontal Line in a separate column?
| [2020-11-12 17:01:19] |
When using the Horizontal Line Tool, you are more limited in where you can place the Price Level. There are only options for Left and Right and then Above, Centered, or Below the line. This is different from a Study where you can place the Value Label into a Column in the DOM itself.
