Date/Time: Wed, 12 Feb 2025 18:09:23 +0000
DOM not loading the numbers
View Count: 465
[2020-11-10 17:04:08] |
User485461 - Posts: 9 |
Hi, I have the DOM configured, the colors are moving but the numbers are not appearing. I guess my susbscription inlcudes market depth data. Please find the screenshot & please help resolve this issue |
[2020-11-10 17:26:00] |
John - SC Support - Posts: 37909 |
The only thing we can think is that either the text colors have all been set to black and/or the text size has been set to 1. Refer to the following: Graphics Settings: Chart Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-10 19:12:27] |
Also refer to this section to make sure you have the proper market data columns added: Chart Trading and the Chart DOM: Customizing Trade DOM and Chart DOM Columns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
