Date/Time: Wed, 12 Feb 2025 18:30:55 +0000
Order Fill Fees
View Count: 460
[2020-11-10 18:46:13] |
The order fill fees are bundled together across a period of time. So you are saying this is not accurate the billing above? We can check our server and confirm if all of these fills are a correct billing. We would expect that to be the case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
