Date/Time: Wed, 12 Feb 2025 18:06:21 +0000
Indicador TICKCOUNTER
View Count: 553
[2020-11-10 14:01:39] |
User456598 - Posts: 27 |
cordial saludo, quisiera saber si este indicador lo tiene sierrachart, es el contador de ticks, cuenta cuantas transacciones faltan para completar 1 barra de 610 en este caso.
[2020-11-10 16:09:55] |
John - SC Support - Posts: 37909 |
From Google Translate: cordial greetings, I would like to know if this indicator has sierrachart, it is the tick counter, it counts how many transactions are left to complete 1 bar of 610 in this case.
Yes, you can use the Countdown Timer to see the remaining number of ticks. Just be sure to set the Input for Display Remaining Range in Ticks to Yes. Refer to the information here: Countdown Timer For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
