Date/Time: Wed, 12 Feb 2025 17:55:18 +0000
Can additional Quick Load presets be added to Expansion Properties Levels tab?
View Count: 580
[2020-11-10 12:45:32] |
User14953 - Posts: 241 |
Tools >Price Expansion Chart Drawing Properties, brings up a window titled "Expansion Properties. The Levels tab shows "Quick Load" squares labeled TC1 - TC8. Question is, can additional Quick Load squares be added to that list eg. TC9... etc? |
[2020-11-10 15:59:11] |
John - SC Support - Posts: 37907 |
We will have to see how it works out with the new dialog windows that we are working on. It is not something we would change at this point. Just be aware, though, that to get to the rest of the Configurations you can just select them in the list box and select Load (or Save). Refer to the information here: Chart Drawing Tools: Using Multiple Drawing Tool Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
