Date/Time: Wed, 12 Feb 2025 19:29:08 +0000
Round number alert
View Count: 756
[2020-11-10 09:28:35] |
grantx - Posts: 244 |
Is there a way to trigger an audible alert when price crosses a round number (without using alerts on lines)? And not a specific price level. All round numbers on the chart. eg 500 increments on EURUSD: 1.18500 1.19000 1.19500 etc... or 50 increments SPX500 3550 3600 3650 etc... |
[2020-11-10 15:46:55] |
John - SC Support - Posts: 37910 |
There is no simple way to do this. You would either need to use brute force (i.e. use an alert like =OR(L > 1.185, L > 1.190, ...), or write your own study to do this. Refer to the following for Alerts: Study/Chart Alerts And Scanning And refer to the following for getting started with ACSIL, if you want to code your own study: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-11 13:48:59] |
Ackin - Posts: 1865 |
grantx) I have the same request from another user, I will create it and it will be in Friday's update (Ackin studies). https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2020-11-11 18:19:44] |
Sudhirc - Posts: 54 |
I have alerts setup on century mark in ES: Charts-->Chart Setting -->Alerts Tab & i had the following condition. =OR(CROSSOVER(C,2400) <> 0, CROSSOVER(C,2500) <> 0, CROSSOVER(C,2600) <> 0, CROSSOVER(C,2700) <> 0, CROSSOVER(C,2800) <> 0, CROSSOVER(C,2900) <> 0, CROSSOVER(C,3000) <> 0, CROSSOVER(C,3100) <> 0, CROSSOVER(C,3200) <> 0, CROSSOVER(C,3300) <> 0, CROSSOVER(C,3400) <> 0, CROSSOVER(C,3500) <> 0) Date Time Of Last Edit: 2020-11-11 18:21:25
