Date/Time: Wed, 12 Feb 2025 18:28:44 +0000
How to Fix Jagged EMAs overlaid to other time frames
View Count: 599
[2020-11-10 09:03:17] |
User338450 - Posts: 1 |
Hello: When I do a study price/overlay of the 15 minute EMA and hull onto the 5 minute chart, the result is jagged and not smooth like on the 15 minute chart itself. Is there any setting to smoothen it out? Thanks! Dave |
[2020-11-10 15:41:27] |
John - SC Support - Posts: 37910 |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. Also, give us a screen capture of what you are seeing so we better understand the situation. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-10 21:12:20] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-11 01:12:44] |
User385365 - Posts: 9 |
http://www.sierrachart.com/image.php?Image=1605056862734.png http://www.sierrachart.com/image.php?Image=1605057099568.png |
[2020-11-11 09:48:00] |
Set the Fill Blanks with Last Value Input to No: Study/Price Overlay Study: Study Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-11 12:07:24] |
O.K. thanks! I knew it was just some setting I missed!
