Date/Time: Fri, 02 Oct 2026 12:29:16 +0000
Can't open any file
View Count: 774
[2020-11-10 07:42:45]
User670350 - Posts: 19
Dear Sir/Madam;
I had some problems with the chart so I deleted all the charts and reloaded them and it still didn't work. Then I uninstalled Sierra and installed a new version and it didn't help.
These are the same chart from TradePro Academy that I was using before with no problem.
I was trying it many times without success after switching off antivirus, restarting computer etc.
I would be willing to pay for the service and actually I applied for it already
Could you help me with that or at least tell me how I can schedule remote-paid service ASAP?
Thank you;
Andrzej
imageSierra 1.jpg / V - Attached On 2020-11-10 07:36:16 UTC - Size: 97.42 KB - 307 views
imageSierra 2.jpg / V - Attached On 2020-11-10 07:36:25 UTC - Size: 687.48 KB - 274 views
Private File
[2020-11-10 09:10:05]
You need to translate the symbols to the current service because they do not match. You need to use this Edit menu command:
Edit Menu: Edit >> Translate Symbols To Current Service
Let us know if that resolves the issue.
Date Time Of Last Edit: 2020-11-10 09:10:11
