Date/Time: Wed, 12 Feb 2025 18:54:10 +0000
Drawings do not remain erased. Tools >> Erase All Non-Text Drawings
View Count: 533
[2020-11-10 06:35:46] |
User14953 - Posts: 241 |
Tools >> Erase All Non-Text Drawings Tools >> Erase All Text When I try to clean up the charts in a chartbook by using the "Erase All ..." commands above, the drawings do not remain erased. What might explain this situation? The drawings were not copied from one chart to another. If the Chart with drawings is the product of a "Duplicate Chart" command, would that explain why these zombie drawings will not delete permanently? Is there a work around? Chart Drawing Tools: Erasing Chart Drawings |
[2020-11-10 15:33:14] |
John - SC Support - Posts: 37910 |
The only reason a drawing would not erase with the Tools >> Erase options, given what you have stated, would be if the drawing was locked. Refer to the information here: Chart Drawing Tools: Locking Chart Drawings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-13 09:20:13] |
User90125 - Posts: 715 |
When this occurs, just open the Manage Chart Drawings window (MCD) and you can unlock and delete the drawings from there. Chart Drawing Tools: Manage Chart Drawings Date Time Of Last Edit: 2020-11-13 09:21:25
