Date/Time: Wed, 12 Feb 2025 18:10:36 +0000
CQG Web API with Denali data from Sierra Chart
View Count: 833
[2020-11-09 22:13:15] |
User2020 - Posts: 1 |
Hi, I had account with Ironbeam, and I would like to use CQG. Can I just only use platform with CQG and no real data from CQG? Is there any technical issue if I purchase Denali data provided by Sierra and connect with CQG? Thank you. |
[2020-11-09 22:20:20] |
John - SC Support - Posts: 37910 |
There are no technical issues with getting your data from us (Denali Exchange Data Feed) and using CQG for trading. Refer to the following Setup Instructions for CQG: CQG Trading Platform Service: Setup Instructions And then refer to the following for integration of the Denali Exchange Data Feed with CQG: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
