Date/Time: Wed, 12 Feb 2025 19:16:23 +0000
Live data feed
View Count: 476
[2020-11-09 16:13:27] |
User944526 - Posts: 1 |
Hi, i would like to update to a live data feed but i am a bit unsure of what package to select. I dont realy require to be linked with any broker just need the data i already recieve but live in real time rather than 10min delay. Thank you |
[2020-11-09 17:38:01] |
John - SC Support - Posts: 37910 |
The CME Group requires that you have a trading account in order to qualify for the lower-priced non-professional exchange fees. Therefore, you really do need to be linked to a broker in order to get the Real-Time data. We recommend using the service described in the following link in order to use a minimum of funds to create a trading account that can be used to validate your non-professional status: Easy Solution to CME Funded Trading Account Requirement For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-12 04:44:32] |
You will need to use the Denali Exchange Data Feed: Denali Exchange Data Feed It is necessary for you to have a futures trading account to receive CME data at the lower-priced nonprofessional fees.This is the solution to use: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-12 04:44:58
