Date/Time: Wed, 25 Nov 2026 16:37:38 +0000
GE eurodollar only displaying day increments on 5 tick chart
View Count: 768
| [2020-11-09 14:01:54] |
| Anapurna - Posts: 10 |
Hi, my chart for GE, Eurodollar is only displaying one candle/day. It is a range chart set to 5 ticks. I tried delete all data and download to no avail. First time setting this up, so maybe that is how the instrument works? Please advise, thank you! GE is CME which worked fine for other instruments on charts like 6J.
| [2020-11-09 17:20:45] |
What you are seeing is due to the low amount of trading that occurs on that symbol. It is simply not reaching 5 ticks within a day, but since you have the setting for New Bar at Session Start set to [/b]Yes[/b], you are getting a new bar each day. You probably should just use a defined time-period to review that chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
