Date/Time: Wed, 12 Feb 2025 17:52:28 +0000
Export to text file
View Count: 480
[2020-11-09 02:54:22] |
charl vorster - Posts: 6 |
Hello Support ; Is it possible to have the values of a manually drawn line objects on a chart exported to a text file ? can't find this info from search on the site thanks |
[2020-11-09 11:14:43] |
Look at the Manage Chart Drawings window: Chart Drawing Tools: Manage Chart Drawings You can select multiple lines of drawings, and use the Copy Text button to copy that data to the clipboard and paste it in a text editor. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
