Date/Time: Wed, 12 Feb 2025 18:09:49 +0000
right click at level - set price alert shortcut?
View Count: 1422
[2020-11-07 18:54:52] |
HeyUgly - Posts: 251 |
hello , looked at i think everything to assign to right click, and i cannot find a simple and quick set price alert shortcut do you have to manually enter every p[rice alerta you want to set in the price alert manager? im hoping theres a faster way to do this? i just want to go to my price lvl, and right click and have the option to set it, please advise if it is possible or have to maually enter it all cheers |
[2020-11-08 00:44:55] |
For instructions to add a Symbol Alert through a chart, refer to: Alerts Manager: Add Symbol Alert Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-09 11:19:08] |
User90125 - Posts: 715 |
Assign Add Symbol Alert to the Chart Shortcut Menu, then you can right click on your price level, and the option should be there |
