Date/Time: Tue, 22 Sep 2026 22:22:03 +0000
New update
View Count: 941
[2020-11-07 03:15:04]
User575399 - Posts: 350
I have Denali and received the notification for the necessary update by November 15th. What happens if we do not perform this update? The reason I ask is I have custom studies that I do not know the original developer or have the source code and now they need to be recompiled. This kind of screws me.
[2020-11-07 03:24:07]
Where did you get the custom studies from? We would think it would not be difficult to locate the source code for them.
[2020-11-07 03:34:13]
I got the chartbook from a friend. He got them from a mentor. That person does not have the source code. Chartbooks and studies are passed around quite a bit,I actually dont find this uncommon as many people do not like to release source codes.
Date Time Of Last Edit: 2020-11-07 03:34:50
[2020-11-09 09:33:54]
Could you attach the Chartbook here so we can see what we can learn about the custom studies and see if we can locate the developer.
Instructions:
The Chartbook will be privately attached.
[2020-11-09 23:54:09]
Okay I attached the chartbook. Please if possible tell me the developer of charts # 3,4,5,7,11,13,16,17,32,33,38 and the smoothed delta study and how I can get the original source code ? The others I made. Thanks for all your help
Private File
[2020-11-10 06:13:24]
Let's take these one step at a time. This is what we see:
SmoothedDelta_64.dll | 2020-11-10 01:06:23.937
sst_pulling_stacking_64.dll | 2020-11-10 01:06:24.151
sst_FreeBundle_64.dll | 2020-11-10 01:06:24.913
SmoothedProfile_64.dll | 2020-11-10 01:06:26.378
What study or studies do you use in SmoothedDelta_64? And what do they do. We probably can just do much of what you are getting from these studies and just add some additional functionality to support this.
[2020-11-10 11:44:20]
Smooth delta is based off study #12 vbp . It lets me see where longs and shorts have traded indicated visually by color . It uses visual studio
[2020-11-10 12:35:36]
Also, is their a way to see who the original developer was ?
