Date/Time: Wed, 12 Feb 2025 16:20:45 +0000
Command/Control Bar_2
View Count: 484
[2020-11-06 19:24:09] |
User00111 - Posts: 111 |
I have two questions: 1) how can I set the long / short buttons with the stop ... example within Long at 3500 stop 3498 ... 2) Custom Study Button1 / TMS allows me to position one stop? == A. |
[2020-11-08 00:35:13] |
You need to use Attached Orders: Attached Orders: Using Attached Orders and Attached Order Settings And then you can set up Trade Window Configurations which you can select through Control Bar buttons: Control Bar: Control Bar Trade Window Configuration Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
